Author Topic: Yamaha 1986 SRX600S  (Read 1186 times)
danielcshea
  • New Member
Yamaha 1986 SRX600S
« on: July 10, 2020, 01:49:30 PM »
My rear master cylinder is shot, a new assembly is not to be found. Any suggestions?
        Thank you
Re: Yamaha 1986 SRX600S
« Reply #1 on: July 10, 2020, 03:08:14 PM »
master cylinders form rear brakes on jap bikes are pretty generic. measure the distance between the bolt holes then have a look through yamahas range.
« Reply #2 on: July 10, 2020, 11:09:31 PM »
Aye Daniel,
I have viewed the online parts list that is readily accessable from Fowler's of Bristol website. The link below will take you to the Yamaha parts list of the 1986 SRX600 rear master cylinder.
SRX600-1xl-1986_rear-master-cylinder
By clicking on the part number of the item, a list of alternative bikes that used the same part are listed and this is very helpful. I attach the link below, having clicked on the part number.
Alternative_bike_models_using_1986_SRX600_rear_master_cylinder
This is the result from my 'Search' of eBay tonight.
eBay_SRX+600+rear+master+cylinder
Finally, if you use the link below, it will take you to 'Jauce', which is the Japanese 'Yahoo' auction site equivilent of eBay. This can be a good source of spares, but for an approximate idea of total costs you should multiply the final bid price in Japanese Yen by three (3) before converting Japanese Yen (JYen) to GB Pounds (GBP). You will need to register and make a deposit before bidding on an item. I used PayPal to make the deposit. Ian on this forum has also used this method to obtain parts for SRX400's that he has rebuilt and it was he who gave me the lead for this.
jauce.com/search/SRX600+rear+brake?
I hope that this give you some leads to make your own research and find the parts you need.
danielcshea
  • New Member
« Reply #3 on: July 11, 2020, 04:44:57 AM »
Thank you for your responses, I have one from my old RZ and the bolt pattern is the same, the piston bore's a bit smaller though. Just bought one of ebay. I hope the bore's the same as stock but will probably try it even if it isn't.
                                               Thanks
« Reply #4 on: July 11, 2020, 10:48:25 AM »
Aye Daniel,
Pleased to help, let us know how you get on and what your solution is.
« Reply #5 on: July 11, 2020, 12:28:06 PM »
Smaller piston will give you a more powerful brake at the expense of greater lever travel. But you knew this....
« Reply #6 on: July 13, 2020, 10:21:20 AM »
You're right of course Ian.... one small point .... smaller piston DIAMETER give more powerful braking at the expense of lever travel :-) but of course we all knew that ...
