Author Topic: Help! electrical problem!! XBR500  (Read 1103 times)
« on: April 02, 2023, 12:14:30 PM »
Morning all,
I need a little help with my XBR. I am currently getting my trusty XBR ready for sale - For various reasons I've hardly used it in the last 2 years and I would really like to move it on to someone else who can enjoy it.
Now my problem is this - while it has been largely stood for the last 2 years it has developed an annoying electrical problem - I have started it from time to time, but sometimes it won't start - no spark. However if you play around with the wiring in the headlamp it will start and run well and start again at a later date, but then stop sparking again. I suspect either a broken wire/ bad connection or the ignition/ kill switch.
In order to illiminate the problem I want to basically 'hotwire it' - i.e. bypass the ignition/kill circuits to see if it will start. Can anyone tell me the best way to do it or any other suggestion to track down the issue.
Thanks
( alternatively if anyone wants to take it on as is for a sensible price for an otherwise really nice, VERY original XBR you can pm me.)
Re: Help! electrical problem!! XBR500
« Reply #1 on: April 02, 2023, 03:31:13 PM »
Hi Steve.
The kill switch actually shorts out the ignition circuit when in the "stop" postion by connecting together the black/white and green (earth) wires. You could test it by disconnecting the black / white which should eliminate that. The ignition switch also shorts out those two wires. I suspect (although am not sure) that if you disconnect the black / white from the CDI then that would achieve both the above. However you will then have no way of stopping it!
The attached should explain.
1992 Yamaha SRV250
« Reply #2 on: April 02, 2023, 07:01:28 PM »
hi steve
The first thing i would do there is take the headlight  off and check the wires in the shell theres not much room in there and wires get pulled apart , and broken tommy
« Last Edit: April 02, 2023, 07:04:36 PM by tommy »
« Reply #3 on: April 02, 2023, 08:17:46 PM »
I've got all the wires out today. I know the problem is somewhere on the front end of the loom it's just tracking it down.....I hate electrics!! >:( >:(
richardeblack
« Reply #4 on: April 30, 2023, 09:24:08 AM »
Did you get it sorted? What was it?
Yes, I hate having the headlamp off the XBR. It always takes me ages to get all the spaghetti back in.
As the switch shorts the ignition to earth, I would doubt a bad connection? Perhaps check the kill switch?
