Author Topic: Any Tips For Re-Fitting A Centre Stand Spring Please?  (Read 702 times)
« on: December 03, 2023, 06:11:12 PM »
I'm rebuilding my GPZ500S project but am struggling with a job I hate as above. I have a spring puller (no good), have tried screwdrivers and the old dodge of putting washers in the spring but all to no avail. I've watched some YouTube vids but seen nothing I want to risk trying at the moment.......
Re: Any Tips For Re-Fitting A Centre Stand Spring Please?
« Reply #1 on: December 04, 2023, 12:19:13 AM »
Mole-Grips?
Spring puller has always worked for me, or the washers between the coils.
Have you tried using two nails, one into the shed/garage door frame and another near to the outside edge of the door? Put the spring over the nails, bent if you prefer, and then use the door to open the coils, so that you can fill it with washers/plywood spacers.
Sorry not to be more helpful. All the best and don't put a spring in your eye!  :o  :-[
« Reply #2 on: December 04, 2023, 07:15:37 AM »
Pain of a job for sure, sometimes literally. In the past I have left the stand unbolted to the frame but attached the spring to the frame and stand, giving me much better pulling holds. Then by locking on one of the brakes and getting an assistant ready with the stand bolts/spindle I have levered one side in and then the other. Can't say it would work on every stand as it needs room to wiggle etc, but worth a try?
Good luck.
« Reply #3 on: December 04, 2023, 11:21:53 AM »
Thanks for the suggestions.
Another is to put the bike on the side stand and lift centre stand up towards the swinging arm to try to secure the spring.
I'll give these ideas a go thanks.
« Reply #4 on: December 10, 2023, 01:05:34 PM »
All sorted now. I got the bike on the side stand and using a bungee to hold the centre stand up I was able to use my spring puller to install on the locating lugs.
« Reply #5 on: December 10, 2023, 07:45:12 PM »
Excellent, when the plan works and you still have 10 digits! ;)
« Reply #6 on: December 11, 2023, 09:15:52 AM »
Yes, all very straightforward with little risk of digital damage keeping the spring puller under controlled tension. Spent the afternoon battling corroded / broken metal fixings in rear plastic mudguard-oh what fun.Getting on with the resto though.
« Reply #7 on: December 11, 2023, 11:50:08 AM »
Great result, you make it sound easy. My own method involves brute force, ignorance and an abundance of expletives 🤣
2023 Royal Enfield Meteor 350
2021 Honda CB125F
« Reply #8 on: December 11, 2023, 08:45:45 PM »
OH! Furry barrows!  ;)
Bill
