Author Topic: indicator flasher unit (SRX)  (Read 1264 times)
« on: July 16, 2007, 10:53:40 AM »
just a little bit of info that might save you a few bob
The flasher unit on the SRX 6/4 is a bit on the pricey side for a genuine yamaha replacement...you can use a standard Halfords unit (2 x 21w + 3w) halfords part number is 202, cost about a fiver, used it on all of my srx's and works fine
beeman
Re: indicator flasher unit (SRX)
« Reply #1 on: July 16, 2007, 09:36:34 PM »
Thanks for the tip. my brothers srx, on the iom, unit has packed up. Funnily enough his unit has 3 leads and mine only two. but mine did work in the his bike. No idea what the extra wire was for, mine is a jap import his is a uk model.
beeman
« Reply #2 on: July 17, 2007, 05:32:19 AM »
Yes indeed beeman, i should have mentioned that. The Halfords unit only has 2 spade terminals, but does work on either a 2 or 3 wire cable, it is plug compatable with either.
cheers
SteveL
