hello again,
I received from Mr Yamaha today 6 washers, 2 spacers, and 2 rubber seals. The cost was awful; suffice to say "a good night out". However, they're important, so genuine Yamaha is was to be.
I went into the solar shed to begin putting it together to check squish and valve clearances.
Noticed that one of the studs I had to replace was shorter than the others; it became evident which one and why when I placed the 3AJ barrel onto the new studs. You cant get the RH rear nut on unless this stud is in the correct the position... Are you getting me, SRX afficionados??
I went to put the 98mm wiseco piston on. Hmmmm. No circlips,
so I thought about re-using the ones from the omega 100mm piston. Just to get the piston on, to allow the head to bolt down etc. Grrrr
the omega ones dont fit the wiseco piston.
I gave up, and started packing everything into the boxes I got them in.... Ah! There's the little packet with the circlips
so thats tomorrow night then!
However (finally, thru my verbal diarrhoea) we get to my questions:
1) any tips on getting circlips in and out? There is a single notch on the wiseco (as opposed to 2 notches on the omega). Do we push the circlip round till the open end is in this little cut-out, and then lever out carefully?? i've always considered myself to be a wee bit ham-fisted, and end up marking the piston (only very slightly, and not anywhere near the rubbing surface).
2) what about in? Gentle persuasion? Where should the "gap" of the circlip be in relation to the notch. Not right at it, I take it? So does one tap it round??
3) and reading the little wiseco insert papers, I'll be needing to check the ring gap. Not done it yet, but am I likely to need to open the ring gap out?? Any info/ advice? I'll probably do this over the weekend
More and more I am thinking about giving the motor to Martin Sweet to put together. However, this feels like a terrible cop-out. And quite against my tight-as-fuck principles. I think it would be a couple of hundred quid in labour (no parts to buy). Confidence is low! (Althought the head job I did one the 620 was slow and steady, but didn't leak any oil, and did run very well. You guys all talked me thru that one too!!
However engine failures are expensive, especially as they tend to wreck stuff as well.....
More head scratching!
Off to bed for angst-ridden, turmoiled sleep. We are also running out of time! Arrrrgh!!
