Author Topic: SRX400 project  (Read 1366 times)
chippit
SRX400 project
« on: June 09, 2008, 07:52:29 PM »
 I bought a 1986 SRX400 on ebay (the devils own web site) the other week, and definetely not regretted it yet. I have not had a bike for 15 years so can,t wait to get an MOT.
I have really found this site helpful, not even knowing how difficult it would be to get parts for a 22 year old bike I have been pleasantly surprised.
Went into my local bike shop in Rugby, ordered fork seals, fuel tap seals etc, and they rang me the next day to say everything but the air filter was in.
Thanks for all the part nos. SteveL they matched up with the book that the bike shop had.
Probably paid full wack and I didn,t have much to show for £78 (small handful of plastic bags) but at least I can make a start.
The bike has been stood for years and so far I have bled new brake fluid through the system and now have brakes although I shall probably replace the hoses.
Found a couple of pin holes in the tank (ordered frosts tank sealer)
Changed the oil and filter
Bought a new battery, amazingly all the lights etc work.
The forks are slightly pitted and have far too much travel, bought a pair of 600 forks for re-chroming for 99p off  'that web site.'
Does anyone recommend new springs at this stage? I have a copy of M@P direct and they have the hyperpro and hagon progressive springs in their catologue.
It's all money but at least it will do more than my petrol landrover to the gallon.
sorry to hassle SteveL but if you can let me have a copy of the manual it would be very helpful.
I need to get paddock stands next then I can get new BT45's ( what size is recommended) it's got metzler rear 120/80-18.62s and front 3.25-18 is this right?
Oh and if any one has a silver left hand side panel in good nick I am looking for one of those!
Hope to see if she runs this weekend, I will know then if I have bought a complete basket case or not.
Prepare yourselves for a load more silly questions
Re: SRX400 project
« Reply #1 on: June 09, 2008, 09:22:03 PM »
SRX600S (US model) manual can be found here. HERE
Re: SRX400 project
« Reply #2 on: June 09, 2008, 10:36:53 PM »
A Landrover too!  ;D You'll fit right in here  ;)
Don't know about SRX's but the Hagon fork springs were good in my XBR and reasonably priced.
I'd save the money on paddock stands, I use a couple of axle stands for the back, put one on the opposite side to the side stand and you can lean the bike up and the swingarm onto it (pad it with some rag to protect the swingarm) then continuing to push the bike up onto the stand levers the rear wheel off the grond and you can push the other stand under the left side of the swingarm.
Sounds precarious but it's actually pretty easy once you're used to it and you'll find it's very stable.
Not sure how to lift the front as the technique I use on the Mastiff wont work (different frame design/exhaust layout...) but I'm sure one of the srx'ists will be able to advise!
Good luck, maybe see you at the rally  ;D
chippit
Re: SRX400 project
« Reply #3 on: June 10, 2008, 07:41:45 AM »
Thanks for the manual,
I've got axle stands I'll give it a go!
Re: SRX400 project
« Reply #4 on: June 10, 2008, 11:11:55 AM »
Hi Chippit!
Your forks should be with you today!  Small world, eh?
And I found WP Proline progressive springs to be excellent, tho about £75 a few years back...
Happy thumping, they are great bikes
chippit
Re: SRX400 project
« Reply #5 on: June 10, 2008, 02:09:14 PM »
Very small world!
Thanks alot
chippit
Re: SRX400 project
« Reply #6 on: June 15, 2008, 07:20:44 PM »
Thanks for the forks Andy, I'll take them to be re-chromed next week.
Tried to start the bike and to my amazement it ran, very briefly on carb cleaner!
The carbs are now off and they were full of old petrol/brown varnish gunk, before I take any thing else apart how difficult are they to clean or is this something for someone who knows what they are doing !
NRP do a kit should I get one of those, I have already replaced the diaphram in the fuel tap, the o ring was completely stuck, both fuel taps are now put back together.
Next job will be to repair the leaking fuel tank with the frost kit.
