Author Topic: XTZ660 '97 Drive Sprocket Removal  (Read 584 times)
« on: May 15, 2011, 01:05:42 PM »
Need to replace the chain and sprockets on the XTZ but don't have a manual. What is the best procedure to 'lock' the sprocket in position prior to removing the holding nut? I assume that it must be a similar to most SRX/XT/XTZ. Is it a lefthand thread?
As most of you will know I usually don't keep bikes long enough to do this sort of thing. The last one I did, Honda Dominator, had a different locking arrangement.
Cheers in advance.....
Re: XTZ660 '97 Drive Sprocket Removal
« Reply #1 on: May 16, 2011, 04:38:08 PM »
skorp (and racer) was just a lock washer and normal RH thread if I remember correctly.
Which I may not!
« Reply #2 on: May 16, 2011, 07:04:02 PM »
Dr. D
"Hay fenk queue!"
Just bought a new lock washer (£2.50 off the shelf @ Granby MC, Ilkeston - v. good) so now I don't have any excuse not to fit new S&S before freefalling into the Rhineland later this month.
guest987
« Reply #3 on: May 19, 2011, 05:54:01 PM »
Shain and sprockets?? :D  { ala sean connery? }
Rob.  :D
OZ
« Reply #4 on: May 20, 2011, 08:42:27 PM »
I tried everything short of voodoo to get the bugger off an XT600e. I then bought a battery powered impact driver.You can't believe how easy someyhing is with the right tool!(As my wife keeps reminding me)
OZ
