A couple of years ago the British Supermono upped the limit of 800cc to no limit. Ive been frantically working on my new bike to get it on the track, but everything takes time when youve got no cash. However it is looking possible to race it next year. So far the project has cost me £1000, and the same again should do for the rest of the bits i need :- piston, clutch, chain, injectors, conrod , bearings, etc
It`s hand milled billet engine runs with Haltech injection, has a massive intercooler under the tank (which actually acts as the top frame), has triple air reed valve inlets into the engine, and a rotary Cross valve head. The seat unit is just one big pressure tank There is no gearbox, just a Revtech clutch mounted on the crank (no cash to buy yet) hopefully the massive pokey and very low friction (there are only two moving parts in the engine) will overcome the need for such. An expected at least 150 hp @ 6000 rpm with a very flat torque curve. This baby can run on most fuels and has a ground compression ratio of 15:1. Unfuelled weight 140 kg.
Its little brother which i learned so much over the past 17 years is a 500cc with an adapted Godden speedway engine with double crankcase inlets, holds the flying kilometer on ice record at 96 mph, and plan to de-bore it to 450cc and run next years Manx where new mono rules allow such.
