Author Topic: FZR 600 swingarm in a SRX 6 frame  (Read 1308 times)
« on: June 23, 2012, 10:17:24 AM »
I want to do this modification for my SRX that will go on tracks.
If someone has good advices or suggestions, I am ready to listen to him ;)
Thanks a lot.
Raphael.
Re: FZR 600 swingarm in a SRX 6 frame
« Reply #1 on: June 24, 2012, 06:23:37 PM »
Which model FZR600 swingarm are you using and are you going to use twinshock or convert to monoshock. I am in the very early stages of fitting a FZR400 (3TJ) swingarm to my twinshock.
« Reply #2 on: June 25, 2012, 12:25:18 PM »
Well, actually I really don't know the year and model it has been extracted from .... It is perhaps a FZR 400 model because I bought it on the bay to an english man. I don't remember and the computer I used crashed (yes, a PC)
I will transform it in a two shock absorbers model like this (I am not enough good at mechanic to weld and install a monoshock and I am not sure it can loosen weight) :
« Last Edit: June 25, 2012, 12:31:15 PM by SRXweb »
« Reply #3 on: June 25, 2012, 07:59:41 PM »
The 3TJ arm looks like this HERE
The main reasons for choosing it was that a) I had one in the loft  b) its the same length as the srx twinshock arm. I also have an SRX monoshock swingarm but its around 50mm longer so chose not to use it.
I have a habit of over-engineering things so I suspect I will be adding a fair amount of weight.
« Reply #4 on: June 26, 2012, 08:26:41 PM »
Mine looks like a SRX 3SX Monoshock swingarm : rectangular alloy.
« Reply #5 on: June 29, 2012, 08:21:15 PM »
Bonjour SRXweb,
Nice 'purposeful' bike in the image!  ;)
Magnifique.
Regards, Bill.
« Reply #6 on: June 30, 2012, 06:50:33 PM »
Yes, indeed.
It is not mine, ... but its a good start to copy.
I'd like to see what is under the tank : new airbox, big filters, ... ?
If someone knows how to calculate the volume of an airbox ??
