Morning chaps es chapesses, my Skorp appears to have some sort of sediment/muck in the floatbowl (will run perfectly most of the time but sometimes suffer a blockage of the mid/main jet, idles fine(with a hint of lean running when the problem manifests itself) but will not rev at all, seems possible to suck the blockage through with a bit of aggressive throttle use so far (touches wood)).
I've stuck some petrol cleaner through it and changed the old petrol pipe to a clear plastic one but the problem re-appeared last week.
Now clearly the next move should be to drop the floatbowl and clean it out properly, but on checking (and remembering my old Z200 where I could drop it at roadside with no tools!
), I discover that I've as much chance of getting access to the float in situ as I have of winning the lottery and living a life of leisure and manx nortons
So my question is... is there an "easy" way to get the floatbowl off or do I have to strip the tank/side bodywork etc etc to pry the whole unit out?
(Not that I'm doing it in the next day or so as I'm off with flu and in the huff!
Cheers, S
