Author Topic: 250 RS oil leak  (Read 571 times)
SHimmer45
250 RS oil leak
« on: July 06, 2012, 07:29:32 AM »
a common fault so im told around the rocker cover area however i have i think sorted this but appear to have a leak/pool of oil between the exhaust ports is there another sealing face which needs looking at there?
thanks
Dick Scratcher
Re: 250 RS oil leak
« Reply #1 on: July 06, 2012, 08:50:36 PM »
If that's a CB250RS, Yep, that oil leak sounds about right, mine does it too. The cambox/cylinder head joint is a metal to metal fit with no gasket. I've had a couple of attempts to stop mine 'sweating' using different compounds which have worked for a while and then thrown the towel in. I suppose that refacing the joint surfaces would help to stop the problem but then it would also reduce the bearing clearance for the camshaft that runs directly in the head so not such a good idea. When I bought mine for fifty quid ten years ago some herbert had had a bash of stopping the leak by using Isopon body filler over the outside of the joint, that didn't work either. If the leak isn't too embarrassing do what I do, wipe it with a bit of kitchen-roll every weekend !. Best of luck.
SHimmer45
Re: 250 RS oil leak
« Reply #2 on: July 08, 2012, 04:06:43 PM »
had a closer look this weekend, rocker cover isnt leaking (at the moment)
but there appears to be a bolt which joins the head to the top of the barrel.
looks like going to have to have the motor out to deal with it as have also a couple of stripped bolts, i think a monkey has been swinging on a spanner....
