Author Topic: oil cooler  (Read 1213 times)
oil cooler
« on: May 19, 2013, 06:35:15 PM »
I finally fitted an oil cooler. I still have to get a cover for the end of the pipe to neaten it up. XBR's run hot, tuned XBR's run even hotter and ruin oil very quickly.
Re: oil cooler
« Reply #1 on: May 19, 2013, 07:57:47 PM »
A very sensible addition  :D
Re: oil cooler
« Reply #2 on: May 19, 2013, 09:16:18 PM »
hi joolz are you using the stock oil pump  tommy
Re: oil cooler
« Reply #3 on: May 20, 2013, 08:21:59 AM »
Yes Im using the standard oil pump, Rebuilt with new seals etc
Re: oil cooler
« Reply #4 on: June 08, 2013, 11:48:29 AM »
The oil cooler has lowered the temps ok, although I had a problem of oil being blown out the breather, fixed that just by adding a longer pipe. I have also fitted a new hose for top end oiling. Its starting to look like a plumbers nightmare
guest1683
Re: oil cooler
« Reply #5 on: July 18, 2013, 03:32:58 PM »
  hey joolz,nice job on the cooler.
im interested in the larger oil feed pipe to the head.can you tell me what fittings and pipe you used?
what about the oil gallerys in the head did you open them up or a hints avise would be great.
thanks T.
