Technical
Project Progress
Carb adaptor
Topic: Carb adaptor (Read 780 times)
Carb adaptor
August 02, 2014, 04:30:51 PM »
Started work on the carb adapter, and insulator. Opened them up to match the head, just need to get the spigot welded to the flange, then thats finished
Attachment Expired
Re: Carb adaptor
August 09, 2014, 10:08:08 PM »
That looks like a top quality job. I had better results across the rev range with a short inlet tract. I did have the bracket for the voltage regulator cut-off though so longer might be necessary if its for road use. I had to make a flange as well as I was told that welding the stock flange was a bit hit and miss because of the high zinc content.
Re: Carb adaptor
August 10, 2014, 09:10:28 AM »
I cut the inlet length so that it would be 31cm from the valve face to the bellmouth intake which is the resonant length that I needed. I know a good tig welder who can do the job ok
guest1154
Re: Carb adaptor
August 17, 2014, 07:59:04 PM »
If you cant get it done....I am a tig welder as well. Just message me if you get stuck.
Technical
Project Progress
Carb adaptor
