This hoary old chestnut returns!
Is anybody any good with CDI ignition diagnosis, PLEASE?
This is a Ducati Electronica system that has the battery charging coils and the ignition power and trigger coils mounted on a common stator plate, with the timing of the ignition spark controlled by a trigger inside the keyed flywheel and an electronic advance circuit within the combined transducer/ coil unit. Similar to equipment fitted to Vespa and Lambretta scooters. BeadSpeed have supplied replacement parts that I have fitted and the engine now idles, but appears to retard the ignition rather than advance it as the revs rise!
I am no further forward with the "Morini the Minx"! Having replaced the ignition power coil, the ignition trigger coil on the stator, the transducer/coil, HT lead, spark plug cap and spark plug and plagued the Morini Riders Club gurus since 2015, all to no avail!
At present, the engine idles steadily at 1,300 to 1,400rpm. If the throttle is opened slowly, the revs rise gradually, the ignition timing mark ('ANT') on the flywheel can be seen to move in a clockwise direction, consequently on a clockwise rotating crankshaft this is further retarding the ignition timing, I THINK
No wonder the engine cuts out and the exhaust pipe glows red.
The engine is supposed to run 36° advance BTDC. Reverting to the original transducer/coil produces the same result, with the 'ANT' mark moving to the right (clockwise), in the same direction as the rotation of the crank?
Answers will be gratefully received and with my limited electrickery ability I shall try to implement them. The professional coil winders, stator rebuilders, have either lost their staff due to retirement, found alternative employment or just aren't interested.
I have also asked The MRC membership for info. advice as well.
Thank you for your time, Bill
