ive stripped the carb 4 times in the last 2 weeks, twice today, the bike starts then after a wee minute it judders like it cuts in and out makin the bike jerk then it stops. if i kick it, it will start again but dies after a few seconds.
it has a new air filter (but its not a performance filter, just stock) new spark plug (once again its definately the right one) and today i drained all the petrol out, cleaned the filter in the tank, flushed the tank with clean petrol then dried it totally with a hairdryer to make sure there wasnt any water in it, it still does the same thing. i also stripped the carb again and cleaned it thoroughly. no dirt etc in it. ive also tried adjusting the air/fuel mixture but to no avail.
its as if it starts to fuel properly then something happens and the fuel supply is cut short. ive checked all the diaphragms in the carb and theyre sorted, the accelerator pump is also functioning correctly.
im really at my wits end here, i need it to get to work on, its sooooo important.
it sounds to me like a fuelling problem but i dont know what else i can do, ive had a few bikes before which ive stripped etc but im by no means a pro, im only 24 and you guys have a much greater understanding of these problems, does anyone have any ideas as to what i should do? should i get a new carb? should i take it to a garage (with all the cash i dont have)? should i sell it and buy a plastic rocket with wheels? should i sell it and buy a skateboard?
damo
