Just a general aside about projects; visited a local workshop today who are "sorting out" a brat/bobber CB750 custom job, for which £8,000 changed hands earlier this year. Purchased from the builder, not through a third party.
Have found that the front wheel is 5mm out of line with the track of the rear wheel.
To add further insult to injury the drive chain run between the rear and gear box sprocket is 7mm from true.
The brake hose material is the same as that used for the petrol lines from the tank to the carbs. Lumps of hose in the carbs and the brake fluid is 'sweating' through the hose, without pressure!
None of the floats in the 4 carbs are the same shape or level.
Three different types of cable used in the wiring, with no block connectors and a selection of cheap bullet connectors, crimped with bare wires behind the insulation, cone crimp connectors, with up to 4 different wires inside and un-insulated crimp spade connectors.
And there is loads more! This is all after the sidestand snapped in half (butt welded with no fillet and then buffed back for a smooth custom finish), whilst strapped down in the back of the van for transport to the workshop, because "It wouldn't run right!".
I thought I had been mauled with the SRX Mono, but this must be sickening. Some of these 'Custom' jobs are scrapyard lash ups with a dinky paint job.
