Thanks to xbally, I now have the pair in full + the larger CB750 disc to go on the XBR.
At the rear, I measured the RS hub to be 4mm wider on both sides. This agrees with a gent who did the same wheel swap in 2012. His solution was to mill the 8mm off the sprocket carrier face in order to avoid using an offset front sprocket;
guest1540
Re: xbr500 cafe racer project - only 2 months to complete
« Reply #31 on: August 12, 2012, 09:10:43 PM »
Quote
Hi, steve mentioned that a cb350 rear sprocket might fit but the mount holes are 5mm out (105mm). I have sourced a cb400 (1979 - 1983) sprocket that has the correct 110mm between the mount holes, 70mm centre and 34T. When the wheel is centered in the swingarm, I have the same 8mm problem with chain alinement. Rather than have a one off sprocked made, (I'm not happy with the possible torc affect resulting from an offset drive sprocket). Also, for ease of future replacement I have had the sprocket flange milled back 8mm. This resulted in several mil off the cush drive carriers and a spacer under the retention circlip. Problem is that I had to strip the wheel for the engineet to mount the hub for milling. If you choose to go down this route you would need to have this work done before the wheel is rebuilt!!!!. Because I now have to rebuild the wheel I am fitting a 2.5 rim also. I made a detailed drawing and took several photos before striping and I'm gona have a go at rebuilding the wheel my-self -can't be that difficult - right!!! End quote.
Given that some consider the RS cush drive to be a bit weak, I'd like to be able to ask him how it all performed.
Does anyone know Guest 1540?
Or has anyone done the mod with a 4mm offset drive sprocket and a 4mm dish towards the sprocket side?
